[quote:febd901713="carundell"][quote:febd901713="fireball2889"][quote:febd901713="carundell"][quote:febd901713="fireball2889"]i have a Jeep Cherokee with 126,000 miles with a 4.0L inline 6. my problem is while driving sometimes between 10- 30 mph the rpms will suddently drop back to idle without me letting of the gas pedal, but if u push the gas pedal down farther the rpms will kick up and the truck will go again i have replaced the tps sensor and the air temperature sensor and cleaned the entire throttle body and have had the fuel system professionally cleaned and these have made the problem a little bit better however i have no clue as to what is causeing this problem
Thx
Matt[/quote:febd901713]
Hey Matt,
What year is that Cherokee? You describe an idle issue. Does the vehicle actually stall? Let me know!
Chris[/quote:febd901713]
Hey Chris
its a 1997 and it doesnt stall but while driving it will just drop back to idle for no apparent reason but ive been tinkering and if u put an octane booster or a fuel cleaner in it, it will only hesitate slightly then go instead of dropping back to idle[/quote:febd901713]
Hey Matt,
Interesting problem .... I would start w/ some of the basics first ........ check tune up, a clogged fuel filter etc ....... some other things would be a faulty O2 sensor. Is your check engine light on or flashing? if so most major auto parts suppliers offer a free scan. If you do this please post back w/ the codes and their description. Let me know!
Hey Chris
no my check engine light is not flashing the truck has brand new fuel fiter, O2 sensor, spark plugs, distributer cap and rotor, and a high flow k&n filter that i just cleaned. ive gone through all the basics and still hasnt fixed it every professionnal mechanic around here cant figure it out.
Oct 15, 2007 at 1:03 AM
