1999 Jeep Cherokee Erratic Idle Dies
PETERSOHNJM
I have a 99 jeep cherokee sport 4.0 V6. I have a new battery and alternator but the other day, I started the vehicle with no problem, the engine and airbag lights came on and the engine began to idle erratically, and then died. If gas is given it will stay running but as soon as you let off it will die again. Can you tell me what I need to do to rectify this situation? Thanks.
Apr 5, 2007 at 11:05 AM
MERLIN2021
  • 17,250 POSTS
Alot of info left out here...Your last tune-up? What are the codes? How many miles on the jeep? Get the codes read if you can. If not goning on the scant info try an Idle air controller, MAF sensor, Or 02 sensor!
Apr 6, 2007 at 8:27 AM
Suggested Repair
Have the trouble codes read first. If codes cannot be obtained, check the idle air controller, MAF sensor, and oxygen sensor, and note recent tune-up history and mileage.
Conversation Summary
A 1999 Jeep Cherokee Sport started normally, then the engine and airbag lights came on, the idle became erratic, and the engine died unless the throttle was held open. The expert said key details were missing, including recent tune-up history, mileage, and diagnostic codes, and advised reading the codes. Without codes, the expert suggested checking the idle air controller, MAF sensor, or oxygen sensor.
