Hesitation while driving
N5836
Ok, I have a 1988 Jeep Cherokee Limited 4x4 271k miles, automatic. For the last 2 years, I've had a hesitation problem at about 50mph going slightly uphill hitting some bumps sometimes, never consitant at aprox. 1700 rpm with engine warmed. This is the most info I can give about the issue, other then it feels like water in the gas or like a hick-up and it's not all the time. It also sometimes dies at stop lights when I stop for long periods of times, again, never consistant. Seems to run and idle ok, maybe a light low idle in gear(750rpm)? I've replaced EVERYTHING in the engine compartment but the engine, head, knock sensor and the ballast resisstor located on the inside drivers side front fender. Have been looking for a engine compartment wiring harness, took all the wires out of the loom and looked them over for any bad connections, none found. Was thinking maybe the ecu/ecm? Acts like a major vacuum leak die at the lights when it dies? Have new 2 part vacuum harness, new crank sensor, new tps, new idle speed sensor, new maf sensor, new egr & diverter valve, new tune-up parts(plugs, wires, cap, rotor, air, fuel), new dist.,new coil, pic-up coil, new temp. sensor, new manifold temp. sensor, new injectors, new fuel pres. reg., new fuel pump, new coolant sensor, new thermostate, new high output 100amp alt., new batt.(800cca), new p/s pump, new rad., new clutch fan, new harmotic bal., new pulley, new a/c cond.(r12), new rad. hoses, new heater core, and all oil leaks fixxed (valve cover, oil pan, main seals, dist. seal). Vehicle has not been in an accident. I'm running out of things to replace, any ideas what I'm missing here?
Oct 31, 2007 at 10:59 AM
N5836
[quote:76e6c7f003="n5836"]Ok, I have a 1988 Jeep Cherokee Limited 4x4 271k miles, automatic. For the last 2 years, I've had a hesitation problem at about 50mph going slightly uphill hitting some bumps sometimes, never consitant at aprox. 1700 rpm with engine warmed. This is the most info I can give about the issue, other then it feels like water in the gas or like a hick-up and it's not all the time. It also sometimes dies at stop lights when I stop for long periods of times, again, never consistant. Seems to run and idle ok, maybe a light low idle in gear(750rpm)? I've replaced EVERYTHING in the engine compartment but the engine, head, knock sensor and the ballast resisstor located on the inside drivers side front fender. Have been looking for a engine compartment wiring harness, took all the wires out of the loom and looked them over for any bad connections, none found. Was thinking maybe the ecu/ecm? Acts like a major vacuum leak die at the lights when it dies? Have new 2 part vacuum harness, new crank sensor, new tps, new idle speed sensor, new maf sensor, new egr & diverter valve, new tune-up parts(plugs, wires, cap, rotor, air, fuel), new dist.,new coil, pic-up coil, new temp. sensor, new manifold temp. sensor, new injectors, new fuel pres. reg., new fuel pump, new coolant sensor, new thermostate, new high output 100amp alt., new batt.(800cca), new p/s pump, new rad., new clutch fan, new harmotic bal., new pulley, new a/c cond.(r12), new rad. hoses, new heater core, and all oil leaks fixxed (valve cover, oil pan, main seals, dist. seal). Vehicle has not been in an accident. I'm running out of things to replace, any ideas what I'm missing here?[/quote:76e6c7f003]
Ok...found the problem, there is a bad wire in the engine wiring harness at the plug-in at the drivers side on the firewall. FYI
Nov 23, 2007 at 2:52 PM
KARLLANES
  • 5 POSTS
I have a similar issue. I'll look at my harness in the same area and see if it looks bad. I'll let you know.
Nov 25, 2007 at 10:15 AM
KARLLANES
  • 5 POSTS
Sorry for two mails. I assume that you are not seeing any fault codes coming from the computer. My failure is like losing all spark and I see a fall in many gages in the instrument cluster. Lights, radio, and other accessories work fine. No sputter or any other hints the problem is coming. Is your's similar? Sounds like it is.
Which side of the connector did you see the issue on? Engine side or harness side? Did you track what circut the short was on?
Nov 25, 2007 at 10:20 AM
N5836
[quote:605769b20a="karllanes"]Sorry for two mails. I assume that you are not seeing any fault codes coming from the computer. My failure is like losing all spark and I see a fall in many gages in the instrument cluster. Lights, radio, and other accessories work fine. No sputter or any other hints the problem is coming. Is your's similar? Sounds like it is.
Which side of the connector did you see the issue on? Engine side or harness side? Did you track what circut the short was on?[/quote:605769b20a]
Think it was on the engine side?, just replaced the whole harness. Check your connections on the battery and the ground connection on the back of the engine block on the passenger side. The ground there is the main one for the computer and everthing.
Nov 26, 2007 at 6:57 PM
