Ground noise under load
JRID123
I have a 1993 Jeep Grand Cherokee V8 with 210,000 miles on it. When I press the gas it is a grounding sound coming from underneath the drivers side. It happens during sharp turns also. I have been told that it is the universal joint or maybe the transmission. The sound doesn't happen if I am act a constant speed, only if I slow down and then type to accelerate. Why do you think.
Nov 27, 2007 at 5:40 AM
MERLIN2021
  • 17,250 POSTS
Well a bad u-joint will clank all the time, and get real grouchy on turns, I suspect a bad mount. either motor or tranny...or a bad leaf spring or shackle...
Nov 27, 2007 at 6:30 AM
