2004 Jeep Grand Cherokee P1756
MSCHAEFERMEYER
2004 Grand Cherokee; 74000 miles; 6 cylinders
My wife noticed last week that her car seemed to be having problems with its auto transmission, and last night her check engine light came on (which is when I of course first heard about the problem). I get the following code of P 1756, which apparently means this: GOV Press Not Equal To Target @ 15-20 PSI. What does this mean, and how much can I expect to pay to have this repaired? I can do basic car maintenance (oil, spark plug, etc.) but I don’t feel comfortable with transmission problems. Also, can we drive the car with this type of problem?
Sep 14, 2007 at 7:24 AM
GRICHARDS
  • 57 POSTS
I see that according to my books, you're right on the money with what your error code means... I dug around a bit - no info that can be helpful . Can you be more specific with "having problems w/ auto tranny"? Forward, backwards...? Other than asking about fluid level and fluid filter change, I can't recommend much - Trannys are controlled by the engine computer and internal solenoid valves do too much for us DIY'S to be able to pull off the backyard fix that we used to able to... You CAN pull off the fluid/filter change if you have patience and a couple of hours - lots of bolts to tweak and tighten, plus getting the damn gasket on and lined up - good luck!
Sep 15, 2007 at 4:50 AM
Suggested Repair
Check the transmission fluid level and condition, and perform a fluid and filter change if service is due. If shifting problems continue, have the computer-controlled transmission and internal solenoids diagnosed rather than attempting an internal DIY repair.
Conversation Summary
The owner of a 2004 Jeep Grand Cherokee reports transmission problems, a check-engine light, and code P1756, meaning governor pressure is not equal to the 15-20 PSI target. They ask what the code means, repair cost, and whether the vehicle can be driven. The expert confirms the code definition, requests more specific shifting symptoms, and recommends checking the fluid level and considering a fluid and filter change, noting that modern transmissions are computer-controlled and not suited to backyard internal repairs.
