1990 Jeep Cherokee Gas Fumes
SHARIK66
I am writing for a friend who has a Jeep Cherokee 1990, almost 200,000 miles with a 6-cylinder engine.
She is experiencing strong gas fumes in the car, but not all the time. She realizes now that it seems to be only when getting gas at certain gas stations (Shell, for one) and the fumes remain until the tank is empty and she puts in a different brand. The gas mileage is also a lot worse at the time she smells the fumes.
Is there any reason why she may experience thiis at certain stations but not others? If it were a gas leak, I would think it would be consistent.
Any information would be appreciated.
Mar 7, 2007 at 12:38 AM
MERLIN2021
  • 17,250 POSTS
if your jeep was 96 or newer you would have a check engine light on! Evaporative emmissions control is out of wack! Can be anything from the charcoal cannister to a cracked vacuum hose in that system. A good mechanic can fix it!
Mar 8, 2007 at 9:44 AM
ANGELALYNN
  • 7 POSTS
Hi: I saw your post & wanted to suggest your friend look for a hole on the inside of the car in the back of the car. I also have a 1990 Jeep that had the same problem. I noticed the fumes after I filled up. It turned out that someone had bolted something in the back of the car before I owened it & the dummy managed to drill a holf right through the gas tank.
Mar 9, 2007 at 4:06 AM
Suggested Repair
Have a mechanic inspect the evaporative emissions system, including the charcoal canister and vacuum hoses, and check the fuel tank and rear floor for a puncture that could let fumes into the cabin.
Conversation Summary
A 1990 Jeep Cherokee with nearly 200,000 miles has intermittent strong gas fumes and worse mileage, noticed after fueling at certain stations and lasting until that fuel is used. An expert attributed it to a faulty evaporative emissions system, such as the charcoal canister or a cracked vacuum hose. Another owner reported the same symptom after a hole was drilled through the fuel tank from inside the rear of the vehicle.
