1993 Jeep Grand Cherokee High Fuel Use
MR_KRIDLEY2000
I have a 1993 Jeep Grand Cherokee and it's consuming a lot of gas. I fill up and drive back home and the tank is back empty; I've checked for leaks and I have none. What could be the problems.
May 18, 2007 at 4:50 PM
MERLIN2021
  • 17,250 POSTS
look on your fuel rail and pull the vac hoses off the pressure regulator. Is there any gas in there? If yes replace it and do an oil change before you drive it again!
May 18, 2007 at 8:21 PM
Suggested Repair
Pull the vacuum hose off the fuel pressure regulator on the fuel rail. If gasoline is present, replace the regulator and change the oil before driving again.
Conversation Summary
The owner of a 1993 Jeep Grand Cherokee reports very high fuel use with no visible leaks. The expert advises checking the fuel-rail pressure regulator vacuum hose for gasoline and, if fuel is found, replacing the regulator and changing the oil before driving.
