1996 Jeep Grand Cherokee Dash Lights Out
BLOOMINIRISH
I own a 1996 Jeep Grand Cherokee Limited 4x4 with an inline 6 cylinder with 230,000 miles. It has run fantastically for all of those miles. The other day while driving, I noticed that while my light switch was in the auto position, my interior light on the dash, message center and upper console blinked from dim to bright several times. Now I have no dash lights, fog lights, parking lights, or console lights regardless of the control switch position. My headlights, blinkers, flashers, and brake lights all work. I have checked the fuses and all are perfect. What do you think could be the problem?
Apr 5, 2007 at 2:10 PM
MERLIN2021
  • 17,250 POSTS
I think the problem is waayyy toooo manyyy miles!
Then if you can reach up under the dash and get the connector off the switch, you'll find either a burned connector or switch...
Apr 6, 2007 at 8:14 AM
Suggested Repair
Reach under the dash, disconnect the lighting control switch connector, and inspect it. Replace a burned connector or a failed switch as needed.
Conversation Summary
A 1996 Jeep Grand Cherokee with 230,000 miles lost dash, fog, parking, and console lights after the interior lights flickered from dim to bright. Headlights, turn signals, hazard lights, and brake lights still work, and the fuses checked good. The expert advised removing the switch connector under the dash and checking for a burned connector or a bad switch.
