2003 Jeep Grand Cherokee Radio Dead
XTYB
The car with the problem (I came back to my car when everything had been functioning fine and it would not start at all. On previous advice, I whacked the battery terminals. When I got back in all the gagues were flickering. The car started right up, but the radio will not turn on. There is no clock, no readout at all from the radio. Is this something I can fix myself?)
is a '03 Jeep Grand Cherokee.
Apr 27, 2007 at 12:36 PM
XTYB
Apr 26, 2007 at 4:51 PM
2CARPRO JACK
  • 11,533 POSTS
What kind of car? Check all the fuses in the underhood and passenger compartment fuse blocks.Might want to get a meter and verify 12+ volts to the power center.
Apr 27, 2007 at 12:48 AM
XTYB
Suggested Repair
Check all fuses in the underhood and passenger-compartment fuse blocks, and use a meter to verify 12+ volts at the power center.
Conversation Summary
A 2003 Jeep Grand Cherokee would not start until the battery terminals were struck. It then started, but the gauges flickered and the radio stayed completely dead with no clock or display. The expert advised checking the underhood and cabin fuses and verifying power at the power center.
