1991 jeep cherokee w/190,000miles. the vehicle has a new fuel pump and filter. it will start and run at idle for approx. 5 seconds and then dies as if it has run out of fuel. at this time if i rev the engine it seems to run longer before it dies. if i disconnect the crankshaft sensor it will not start at all, does this mean that the sensor is good? or could it be another sensor causing the problem
Feb 28, 2006 at 1:42 AM
