1993 Jeep Cherokee Brake Pedal to Floor
FUZZ05
I have a 1993 jeep cherokee. I replaced the pass. side caliper. I bled the brakes and when i pump the brakes the peddle gets hard and then release the peddle then press again it goes straight to the floor. What could cause this?
Jul 22, 2007 at 5:33 AM
DPWD23
  • 136 POSTS
Air in the system, leakey line, faulty caliper, other faulty components, internal leak in the maser cyl. A lot of things could cause this.
Try bleeding the brakes again starting with the furthest away (right rear, then Left rear, Right front, then Left front). Make sure you get all air out, and make sure you are tightening the bleeder screw TIGHT before the pedal is released.
Jul 22, 2007 at 6:47 PM
Suggested Repair
Rebleed the brakes starting at the right rear, then left rear, right front, and left front, tightening each bleeder screw fully before releasing the pedal. If the pedal still sinks, check for a leaky line, a faulty caliper or other component, and an internal master-cylinder leak.
Conversation Summary
The owner of a 1993 Jeep Cherokee replaced the passenger-side caliper and bled the brakes, but the pedal firms up, then goes to the floor on the next press. The expert said possible causes include trapped air, a leaky line, a faulty caliper or other component, or an internal master-cylinder leak, and recommended bleeding again from the farthest wheel while closing the bleeder before releasing the pedal.
