BRAKE shake
SERVICE WRITER
  • 9,123 POSTS
Easy on the caps, I can hear you.
The surface I refered to was the hub surface between the studs.[img:6a58df97c8]http://www.2carpros.com/forum/automotive_pictures/30961_hub_1.jpg[/img:6a58df97c8]
Not knowing what vehicle you have makes it a little tougher to help due to charactersics of some of them.
Thus this note before you posted.
[img:6a58df97c8]http://www.2carpros.com/forum/automotive_pictures/30961_note_2.jpg[/img:6a58df97c8]
If you have a grand cherokee I have seen dampner cause what you are describing, but from higher speeds typically.
[img:6a58df97c8]http://www.2carpros.com/forum/automotive_pictures/30961_dampner_1.jpg[/img:6a58df97c8]
Perhaps this is coming from rear rotors? That was why I asked of there was any difference whatsoever in the before and after effects.
Jan 21, 2007 at 2:29 AM
SERVICE WRITER
  • 9,123 POSTS
What speeds is this happening at. Thruway? short stop and go?
What vehicle?
HAs the shake changed whatsoever after your work compared to before? Sometimes you can get a bad rotor, but it will change a little from before and after.
Did you clean the hub surface before putting on the rotors?
Jan 21, 2007 at 1:11 AM
ROCC49
  • 6 POSTS
happens at any speed-as soon as i touch the pedal. I did NOT CLEAN the surface before installing it. I didnt know i had to because it it NEW.
Jan 21, 2007 at 1:35 AM
CLEAVAGE4U
  • 69 POSTS
What kind a car you have sweetheart? I Think Mr. Service Guy meant the surface that the new rotor mounts to, silly. I think you need to answer on if there were a change too. Us girls are a whole lot better at communicatin :wink:
Jan 21, 2007 at 1:41 AM
ROCC49
  • 6 POSTS
When i apply the brakes, the front drivers side shakes violently. I replaced the Rotor and pads. That did NOT fix the problem.... HELP !!! :x
Jan 21, 2007 at 7:03 AM
ROCC49
  • 6 POSTS
the vehicle is a 90 Cherokee Loredo 6 cylinder 220,000 miles. There is very little change with the new parts.
Jan 22, 2007 at 12:34 AM
SERVICE WRITER
  • 9,123 POSTS
Since there was some change, you may have bought new rotors that are warped, it does happen. Also the above may still be possible.
Jan 22, 2007 at 2:16 AM
CARUNDELL
  • 602 POSTS
[quote:a2cb0980ef="rocc49"]the vehicle is a 90 Cherokee Loredo 6 cylinder 220,000 miles. There is very little change with the new parts.[/quote:a2cb0980ef]
Hey rocc,
A loose/worn tie rod end or ball joint can also cause this condition.
Chris
Jan 22, 2007 at 2:46 AM
CLEAVAGE4U
  • 69 POSTS
Hey there Mr rockhard,
Didja fix yer shakin?
Feb 2, 2007 at 11:30 AM
ROCC49
  • 6 POSTS
nope---back to the drawingboard----Tie rods/bushings are next
Feb 2, 2007 at 12:43 PM
