2002 Jeep Grand Cherokee Brake Lights Out
APOOLE
I have a 2002 grand cherokee. All lights work fine except my brake lights. I do not have any brake lights when the head lites are on or off. tail lites are fine hazards are fine. clean all contacts, fuse is good, changed all bulbs. made sure bulbs are same type.
Still no luck. HELP
Sep 20, 2007 at 11:55 AM
MERLIN2021
  • 17,250 POSTS
Check the stop light switch on the brake peal arm...find the switch...push it straight forward, then pull up on brake pedal, if lights work you are go to go. If not replace the switch...
Sep 20, 2007 at 12:01 PM
Suggested Repair
Check the stop-light switch on the brake pedal arm. Push the switch straight forward, then pull up on the brake pedal. If the brake lights work, the switch was out of adjustment; if not, replace the switch.
Conversation Summary
The owner of a 2002 Jeep Grand Cherokee reports no brake lights with the headlights on or off, while the tail lights, hazard lights, fuses, contacts, and bulbs are fine. The expert advises testing the stop-light switch on the brake pedal arm and replacing it if the lights still do not work.
