94 Grand Jeep Cherokee
BENK
I just got a new fuel pump put in, and its working fine, but the day after i got it back, its been making weird noises when turning left or right. Its getting harder to make turns, the steering wheel isnt turning as easily, and it makes a bad cranking/grinding noise. Im pretty sure the front shoulders (i think thats what they are called) were replaced recently. The noise presents itself even if not moving, just turning the steering wheel when parked. Is it just that the power steering fluid is out? or is there a bigger problem?
Aug 14, 2007 at 4:37 PM
TURBINEMAN33
  • 5 POSTS
if there is no power steering fluid that's will cause the hard steering and the noise when just moving the steering wheel.if there is no fluid in the resevior more than likely your power steering pump or power steering hose is leaking
Aug 14, 2007 at 5:37 PM
