2007 Jeep Cherokee Brakes system is on
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAZAIMEH
first of all , i'd like to thank you for your help , when i turn the steering to left or right to the maximum the light Is the brake system ABS and ESP is on for 5 minutes then turn off .. is this normal or i have a problem ?
thank you again
Apr 17, 2010 at 9:37 AM
BMRFIXIT
  • 19,053 POSTS
Should not come on
Check wiring harness and ABS sensors at the front tires
Apr 18, 2010 at 1:55 AM
