2006 Jeep Cherokee Water vs. Electrical
43,000 MILES • 6 CYL • 4WD • AUTOMATIC
HIRSCHBP
Anytime water from either a heavy rain or cleaning gets under the hood, the CHECK ENGINE ligh comes on.
I have taken in the car for repairs and they replaced the ignition switch, but the problem keep occuring.
Any thoughts?
May 26, 2010 at 2:58 PM
  • 31,937 POSTS
Hi there,
Have you had any work done on the engine electrics, often when sensor plugs are removed there is a small rubber seal in the plug that does two things, help keep water out and ensures a sung tight fit for the plug, if one of these seals is missing this can be your problem, what codes are set in the ECU?
Mark (mhpautos)
May 26, 2010 at 4:00 PM
