2006 Jeep Cherokee No windows or door lock power
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
DARKKNIGHT369
Good day guys. My girlfriend is having a problem with her 04 Jeep Cherokee windows and door locks. They stopped working about 2 months ago. I checked the fuses and they look ok (none says window). They key alarm unlocks every door except the drivers door and none of the windows work with either the master switch or their individual switch. And when we turn on the headlights the dashboard lights go dim and the dimmer adjustment switch doesn't work. What am I missing here.
Jun 9, 2009 at 8:14 AM
MERLIN2021
  • 17,250 POSTS
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear. Post all codes found...
Jun 9, 2009 at 9:42 AM
