2006 Jeep Cherokee Fog lights
2006 JEEP CHEROKEE
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDHOW91
  • 7 POSTS
Hi
I installed new fog lights to our grand cherokee using the harness already installed. I replaced the indicator/light control arm with a new unit that includes the fog light (pull out) switch but still cant get the lights to work
Any ideas?
Apr 12, 2010 at 7:46 AM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Hi
Did you install a fog lamp relay and a fuse in #15 20A?
Let me know
Thanks for donate
Apr 12, 2010 at 10:23 AM
ANDHOW91
  • 7 POSTS
Thanks for the reply
I did not replace or add any fuses. I downloaded the fuseboard schimatic and see that it needs a 20amp fuse in #15.
I will do that when I get home
Not sure about the relay though, where is it please?
What should I look for?
Thanks again
Apr 12, 2010 at 10:32 AM
DOCFIXIT
  • 18,828 POSTS
It is in underhood box where #15 fuse is should have an empty spot for fog relay
Apr 12, 2010 at 10:42 AM
ANDHOW91
  • 7 POSTS
Great
I was thinking that the fog relay and fuse where 2 different things :-)
I already looked and the slot is empty so Autozone here I come
Thanks again
Apr 12, 2010 at 10:53 AM
ANDHOW91
  • 7 POSTS
Hi again
So I took a look and the fuse is in place (20 amp) but there is no relay in the slot to the left of the #15 fuse. It looks like a plug in multi prong type would you know the part number?
Apr 12, 2010 at 4:21 PM
DOCFIXIT
  • 18,828 POSTS
Advance Auto relay # R3074Z
Apr 13, 2010 at 10:50 AM
ANDHOW91
  • 7 POSTS
Hi
Well if finally fitted the relay and to my surprise it still doesn't work
So I have rechecked the fuses, relay, switch and wiring and all seem to be correct.
Any other thoughts?
Thanks again
Andy
Apr 20, 2010 at 8:53 AM
DOCFIXIT
  • 18,828 POSTS
Check for voltage at fuse, across fuse and at terminals 30-86 at relay
Apr 20, 2010 at 3:03 PM
ANDHOW91
  • 7 POSTS
Any chance we could set up a call to talk live?
I would really appreciate the support
Warmly
Andy Howard
214-864-7631
Apr 26, 2010 at 5:21 PM
