How do i remove the existing fron and rear rotors once the calipers are removed? thanks
Mar 28, 2010 at 10:15 AM
BLUELIGHTNIN6
✓Experienced Mechanic
after caliper is removed then just remove the O-ring that secures the rotor on the hub (front) or to the axle studs (rear). then the rotor will slide off
Mar 28, 2010 at 2:18 PM
PTOPLEY
MEMBER
1 POST
Thanks for the information to remove the front and rear rotors from my jeep grand cherokee. I all makes sense. Appreciated!
