2005 Jeep Cherokee
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISTIAN777
code po303 cylinder 3 misfire detected also po42o catalyst efficiency below threshold bank thanks for any help
May 10, 2009 at 2:57 AM
  • 110,251 POSTS
The converter issue is most likely being caused by the missfire. Have you replaced the plugs and wires? Checked engine compression?
May 17, 2009 at 8:40 AM
