Reverse to Drive and back again I hear a Whine?
97,299 MILES • V8 • 4WD • AUTOMATIC
HOMEY41K
When I shift from Park to Reverse to Drive and back again I hear a Whine with each shift, I would like to get some idea what this is and what needs to be done to correct it.
Dec 12, 2007 at 4:27 PM
  • 75,988 POSTS
You might need to adjust the gear shift linkages, if it checks out and continues to whine you have an internal problem with the transmission.
Dec 12, 2007 at 6:39 PM
  • 55,691 POSTS
The transmission will whine when the fluid filter is clogged here is how to change it out to help fix the problem.
Mopar ATF +4, Automatic Transmission Fluid,
This guide can help walk you through the steps with instructions for your car are in the images below.
Sep 7, 2024 at 2:03 AM
