2004 Jeep Cherokee REMOTE START
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARIANNE143
THE REMOTE STARTER STARTS THE CAR BUT THE KEY WILL NOT TURN IN THE IGNITION.
Feb 7, 2010 at 5:09 AM
  • 110,248 POSTS
Try two things. First, if you have a different key try that. Also, at any parts store you can get a lubericant for tumblers. Get that and spray that in the tumbler to see if it helps. If it doesn't, you will need to remove the tumbler to see if it is bad or the linkage to the ignition switch.
Feb 8, 2010 at 1:00 PM
