2004 Jeep Cherokee Heating Ploblem
96,782 MILES • 6 CYL • AWD • AUTOMATIC
EDGARDOSILVA
  • 9 POSTS
I have a GC special edition the over heat when i drive on the freeway after about 20 minutes running at 65mph the temperature needle stars move up and down from the normal to almost red zone and some times to the red zone the cause me pull over. I'm already change the fan cooling because was bad the low rad operation change the tst and the antifreezee and clean up well the radiator but still the problem.
Mar 22, 2010 at 12:55 PM
  • 75,988 POSTS
Hi Edgardosilva, Welcome to 2carpros and TY for the donation.
Lets replace the thermostat for a start if it continues checked the radiator coolant level if okay also check if its clogged and water pump moving coolant thruout the engine and radiator. If there's no actual boiling over could be the coolant temperature sensor is out of calibration. Let me know what's happening
Mar 24, 2010 at 9:33 AM
EDGARDOSILVA
  • 9 POSTS
Thanks for you reply... rasmataz
I checked all those things seem to me working properly no leaks new thermostat new water pump almost new radiator so I change the temperature sensor from the dealership but still the problem. How calibrate the coolant temperature sensor?
Mar 28, 2010 at 12:47 AM
  • 75,988 POSTS
Use an ohmmeter to read the coolant temperature sensor. The normal resistance on an engine with 50 to 80 degrees F = 2,200 to 2,700 ohms. As the sensor temperature DECREASES, the resistance value will INCREASE.
Mar 28, 2010 at 1:01 AM
EDGARDOSILVA
  • 9 POSTS
I used an ohmmeter and gave me almost 8000hms when is cool. Stars warming up (temperature incleases) the resistances stars to decreases and when gets normal temperature (195 F) the reading is about 600 F. What that meas?
Mar 31, 2010 at 8:03 AM
  • 75,988 POSTS
For engine coolant temperature sensor testing, first disconnect the sensor wire and attach the red lead of the DVOM (Digital Volt-Ohm Meter) to the sensor terminal. Now attach the black lead of the DVOM to the ground. Set the meter to the 20K scale and observe and record the reading. Run your engine for two minutes and observe and record the reading again. The minimum difference must be more than 200 ohms.
Mar 31, 2010 at 9:10 AM
EDGARDOSILVA
  • 9 POSTS
The first reading was 199 Ohms after the 2 minutes running was 205 Ohms
Mar 31, 2010 at 10:30 AM
  • 75,988 POSTS
Test the coolant temperature sensor again and compare to typical values below if its out of specs replace it.
https://images.2carpros.com/forum/automotive_pictures/12900_cts_39.jpg
Apr 1, 2010 at 10:54 AM
