door lock actuator key fob not working
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
MMARINCIC
The door lock actuator from the key fob will not work anymore. I have changed batteries and it doesn't do any good I have had it to the dealer and they said the receiver has to be changed. How expensive is this and where is it located?
Sep 5, 2008 at 10:42 PM
MERLIN2021
  • 17,250 POSTS
DESCRIPTION The Remote Keyless Entry (RKE) system Radio Frequency (RF) transmitter is equipped with three buttons, labeled Lock, Unlock, and Panic. It is also equipped with a key ring and is designed to serve as a key fob. The operating range of the transmitter radio signal is up to 10 meters (30 feet) from the RKE receiver. Each RKE transmitter has a different vehicle access code, which must be programmed into the memory of the RKE receiver in the vehicle in order to operate the RKE system. Two transmitters are provided with the vehicle, but the RKE receiver can retain the access codes of up to four transmitters in its memory.
Sep 5, 2008 at 11:04 PM
