crankshaft position sensor location?
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEEPGUYWB
How to reinstall a cam sensor in a 2004 Jeep Grand Cherokee 4.0 engine?
Jan 1, 2009 at 2:44 PM
JNOVACK
  • 723 POSTS
Hello, Here is a guide to help you see what you are in for when doing the job with diagrams below of the camshaft sensor location for both engines. https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
https://images.2carpros.com/forum/automotive_pictures/52960_0900c15280043258_2.jpg
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Jan 2, 2009 at 3:45 AM
NOSCOT
have a 2002 jeep grand cherokee 4.0L when starting it just cranks first 2 trys when starting then turns over 0n 3rd try-runs great after it starts, where is crankshaft sensor located on this eng. and is it difficult repair
Dec 7, 2020 at 1:13 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check fuel pump and fuel pressure crank sensor by the rear at the bellhousing
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_273.jpg
HEEEEETHIN
Other Category problem
2001 Jeep Cherokee Engine Size unknown Four Wheel Drive Automatic 60,000 miles
can not find where this litlle item is located if you could give me an exact location it would greatly be appreciated
Dec 7, 2020 at 1:14 AM (Merged)
MERLIN2021
  • 17,250 POSTS
It's on the transmission Bell housing, left side...
https://images.2carpros.com/forum/automotive_pictures/62217_CKP_3.jpg
  • 75,988 POSTS
Its on the left side of the transmission bellhousing see below.
https://images.2carpros.com/forum/automotive_pictures/12900_cps_5.jpg
Is there anything else I can help you with?
MERLIN2021
  • 17,250 POSTS
Get me a cold BEER!
  • 75,988 POSTS
Hey Mike
When I post this reply my monitor flashes then it opens then here you are-Wow! kind of freaky. For some reason were hitting the same subject at the same time. Sometimes I win and sometimes I lose.
Drink 1 for me will you-its nite time there for it.
JIM FRY
  • 15 POSTS
Engine Mechanical problem
2001 Jeep Cherokee V8 Four Wheel Drive Automatic 102.00 miles
01 grand cherokee 4.7 v-8 where is it located
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_crk_1.jpg
On right side of engine block,above starter motor.
D12345ODGER
check engine light came on, diagnosed as crankshaft position sensor, where is it ?
DOCFIXIT
  • 18,828 POSTS
Right side engine block above starter
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_162.jpg
CHULEGAARD
  • 35 POSTS
My 1999 did the same thing and the sensor is in an impossible spot to fix on the bottom of motor above the transmission. I was told that if the vehicle isn't acting up don't fix it...somewhat of a dummy light.
SAM WELLS
Where is the crankshaft positioning sensor on the 2000 cherokee 4.0 engine? Do you have to pull the starter to change it?
JDL
  • 16,098 POSTS
Welcome to the forum, my info shows this for crank sensor location.
https://images.2carpros.com/forum/automotive_pictures/170934_jeep_crank_sensor_1.jpg
CHULEGAARD
  • 35 POSTS
It's in a horrible spot and it's a common Dumby check engine readout. If the car runs good don't replace it
Dec 7, 2020 at 1:15 AM (Merged)
MADLPN
Noises problem
1999 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
My 99 jeep grand cherokee dies if it goes below 1000 rpms and if it goes above 2000 rpm it constantly jerks. Also the oil pressure gauge is not working properly at times it will fluctuate between 20-40 but most times it stays near 0. My ex husband just recently replaced both the ignition coil and the crank shaft sensor unit in the last 3 months. A mechanic friend told me to get in the jeep and turn the ignition key on then off and then on and off and then on and watch for anything to pop up such as the check engine light flashing and count the flashes I did try this but what i got from the dash controls was where the mileage is this appeared "P 0352 P 1391 done" done this mean anything and what is the best thing to do. Also today the trans over temp light came on and the overdrive off light came on. Once I turned the vehicle off for a while and restarted it this went off.
Dec 7, 2020 at 1:31 AM (Merged)
JNOVACK
  • 723 POSTS
P0352 is for the coil being faulty and the P1391 is for the cam and crank sensors being faulty but befor you change them change the spark plugs and wires cap and rotor then try it if it still has probblem then you are looking at changing the sensors and coil
