2004 Jeep Cherokee
AL LAKE
  • 2004 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 82,000 MILES
The heater will not go off the defrost setting. If I move the control to floor or dash the heat still comes out of the defrost.
Sunday, November 22nd, 2009 AT 2:21 PM
  • 109,867 POSTS
What you are looking for in this case is a vacuum leak. The vents are actuated by vacuum. When there is a leak, everything comes out the defroster. Check for leaks under the dash, follow the supply hose from the controler through the dash and to the engine. NOTE: Chrysler uses plastic tubing which connect with rubber ends. If there is a problem, the plastic will be cracked and not easy to find. I always start at the controler in the car to see if there is vacuum making it there from the engine. From that point, I know which direction to check, toward the engine or under the dash.
Let me know if you have questions. Also, with the engine running, you may get lucky and hear a hissing sound where the leak is.
Sunday, November 22nd, 2009 AT 9:56 PM
