2003 Jeep Cherokee What to do?
2003 JEEP CHEROKEE
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
SSCHATTEMAN
I went to a place to get a inspection they let me know I need new seals for the rear axles and brakes. Should I replace the seals or the axle? Also do you have to have the seals or axle replaced to pass a saftey inspection. Also they told me my upper tie rod was loose and need to be replaced before it would pass. Is that also something needed for a saftey inspection?
Feb 17, 2009 at 1:58 PM
  • 31,937 POSTS
Hi there, you will have to get the seal & wheel bearing replaced as a set, oil will be causing a problem on the brakes if this is not rectified, and i think that they are referring to an outer tie rod end, if faulty along with the rear seal they will be items required to be fix for road worthy condition.
Mark (mhpautos)
Feb 17, 2009 at 6:08 PM
