2003 Jeep Cherokee P0205 & P0305 codes
99,600 MILES • 6 CYL • 4WD • AUTOMATIC
DBISH_01
I own a 2003 Jeep Grand Cherokee Laredo: 4x4 with a 4.0L. Recently the above listed codes popped up on my computer. Naturally thinking it is an injector problem, I replaced the injector in cylinder 5. Unfortunately, the problem was not fixed. To ensure there was a good signal going from the harness to the injector, I used a noid light. The light was consistent with no gaps or pauses; there was a constant pulse. Does any one know where I go next?
Jun 15, 2010 at 7:11 AM
BLACKOP555
  • 10,386 POSTS
check voltage drops of that injector and compare with others. wires in the connector can be to bad to open injector properly but easily light up a noid light!
do you have access to an oscillisope?
Jun 15, 2010 at 2:38 PM
DBISH_01
I do not have an oscilloscope. Is it a tool I can rent from a parts store? What readings should come across?
Jun 16, 2010 at 4:36 PM
BLACKOP555
  • 10,386 POSTS
there expensive... thats for sure. go with noidlight for now. i doubt you can rent an oscope from anywhere tha ti know of
Jun 16, 2010 at 4:49 PM
CJCYR8
Dbish_01:
I am having the exact same problems with my 2004 Jeep Grand Cherokee Laredo 4x4 4.0 I6 with 117,000miles....How did you fix this...Thank you..
Dec 20, 2010 at 11:01 AM
