2003 Jeep Cherokee no right side heat
2003 JEEP CHEROKEE
36,234 MILES • V8 • 4WD • AUTOMATIC
HOT4RD
  • 5 POSTS
I have heat on the left side and cold on right side with dual climate control-any tip?
Dec 13, 2007 at 1:54 PM
GABRIEL_01
  • 6 POSTS
[quote:29294644bb="hot4rd"]Heater problem
2003 Jeep Cherokee V8 Four Wheel Drive Automatic 36234 miles
I have heat on the left side and cold on right side with dual climate control-any tip?[/quote:29294644bb]
I just had the same proble but with the passanger side a jeep climate control system has actuator for each side that open a Air Blend Door to let heat enter well if you have a dad actuator you have no heat coming out that side
Dec 18, 2007 at 10:05 PM
BRETT1818
  • 10 POSTS
That happened to me also on my 2001 Jeep G.C. It is a pretty common occurrence in Jeep's, and unfortunately its quite expensive too if you do not have a warranty left on the vehicle. The dealer will have to replace the little plastic valve that opens and closes to bring warm air into the Jeep. From what I was told it was mostly labor that was the cost, they basically have to take apart the entire front dash to get to the part to replace it. I believe it cost me about 1200 bucks!!
Jan 2, 2008 at 9:13 AM
