fuse for the blow motor/turn signal keeps blowing out?
62,000 MILES • 6 CYL • 4WD • AUTOMATIC
KFOSTER1153
The fuse for the blow motor/turn signal keeps blowing out. have replaced it numerous times, however as soon as the ignition is turned, the new fuse blows. The check engine light also came on the last time i replaced the fuse. Not sure what to do next...Any information would be greatly appreciated.
Dec 15, 2007 at 10:04 AM
  • 75,988 POSTS
It sounds like you have a short to ground, which will cause the fuse to blow.
Dec 16, 2007 at 5:43 AM
  • 55,627 POSTS
Yep, I agree with RASMATAZ, I would remove the turn signal bulbs and inspect the bulb socket which can melt and cause this issue. Please go over this guide which can show you what I mean.
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Please go over this guide and get back to us.
Oct 29, 2024 at 9:33 AM
