2003 Jeep Cherokee car drives for a 5 to 10 miles and then
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
STRRACING
i've had the computer flash , new cam sensor,new fuel pressure regulator/filter. new sparkplugs.fixed all vacum leaks,all four - o2 sensors - up stream and down stream, but drives a little while drops dead ,hope you can help please ,thanks -- dave -
Jun 7, 2010 at 1:14 PM
  • 75,988 POSTS
Hook up a fuel pressure gauge and monitor the pressure if okay could be an ignition component such as coil, distributor pick-up coil, ICM and crankshaft positon sensor, ASD relay, and ignition switch
Jun 7, 2010 at 7:29 PM
