2003 Jeep Cherokee brake lights
120,000 MILES • V8 • 2WD • AUTOMATIC
BRUCE BUELTEMANN
when I turn lights on both tail lights work fine. When I step on the brake pedal the right tail light goes out. The left tail light works fine. I have replaced bulb and socket. I also have moved bulb from side to side and problem stays on the right side.
Aug 14, 2010 at 11:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ground wiring probably is bad or loose at that specific assembly.
Aug 14, 2010 at 11:09 AM
