What would be the possible causes for the engine to crank normally but will not start. (no ignition)?
Nov 11, 2009 at 4:46 AM
JDL
✓Experienced Mechanic
Welcome to the forum, have a helper crank it, while you check for spark at the plugs, If you have spark everywhere, use a gage and check fuel pressure. If no spark, check primary voltage to coil and injectors.
Can you hear the pump run for a couple of seconds when you first turn the key on, no crank?
