2002 Jeep Cherokee Right rear tail light assembly
JEEPSTER80
2002 Jeep Cherokee
I need to replace the brake light bulb. There are 2 screws holding the assembly on the inside hatch, the assembly is loose but there must be a clip or pin holding the assembly in place. I don't just want to yank it out.
What holds the assembly in place other than the 2 screws?
Thanks
Feb 23, 2009 at 8:00 AM
  • 110,248 POSTS
Hi:
I believe there are rubber grommets holding the one side. You should be able to remove it with a little pressure.
Feb 26, 2009 at 10:59 AM
