2002 Jeep Cherokee heat problem
77,000 MILES • 6 CYL • 4WD • AUTOMATIC
JKRASSOW
my heater isn't working properly. The vents on the driver's side blow hot air, but the vents on the passenger side blow cold air, even when adjusted to high.
Dec 2, 2008 at 6:00 AM
MECHCURT
  • 184 POSTS
Look up under the dash on the passenger side and you should see where the heat should be coming from. The only thing i can think of would be a door not opening. These are usually ran by vacuum. try and see if the lvac lines are hooked up. sorry been awhile since i worked on the vents of a cherokee. Let me know what you find and ill do some reading. Hope i can help Curt
Dec 3, 2008 at 9:45 AM
