2002 Jeep Cherokee Grand Cherokee 2002
2002 JEEP CHEROKEE
83,000 MILES • 6 CYL • 4WD • AUTOMATIC
FNAVAS
Every morning my 2002 Jeep grand Cherokee start perfect ,but after 5 to 8 minutes, the engine start to hesitate and most of the time shut off. First computer reading ,the thermothat, i replaced . Now is worst the problem still and after shut off, i can't re start the engine. If I wait to the following day. Them start like nothing happen before. please can you help.
Jul 29, 2010 at 7:53 AM
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it not to start-something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing.
Jul 29, 2010 at 3:52 PM
