2002 Jeep Cherokee fuses
DISNEYLAND
Electrical problem
2002 Jeep Cherokee 6 cyl Front Wheel Drive Automatic
my daughters 2002 jeep cherokees back lights and running lights went out at the same time......could this be a fuse problem? if so, could you tell me where to find it? thank you for your help! Dennis Hughes
Dec 8, 2009 at 7:02 AM
JDL
  • 16,098 POSTS
Welcome to the forum, as far as the back-up lites, check fuse 20-- 10 amp fuse in junction box, My info shows box to be located under left side of dash. Use testlite on the circuit, that circuit goes hot when you turn key on. That circuit also goes through the neutral switch.
Dec 8, 2009 at 8:05 AM
