2002 Jeep Cherokee FRONT BRAKE PROBLEM
95,000 MILES • 6 CYL • 4WD • MANUAL
MIORICU
AFTER A STRONG BRAKE,ME STUCK BRAKE PADS .WHAT I CAN DO?
Jun 26, 2010 at 6:09 PM
  • 31,937 POSTS
You will have to check for a mechanical problem, may be a seized piston, you can try and open a bleeder to see if it is a hydraulic problem, if the brakes back off with the bleeder open it will be a hydraulic pressure retension problem, if you have any doubts about working on braking systems,best to get a qualified mechanic to check this out for you.
mark (mhpautos)
Jun 27, 2010 at 12:24 AM
