2002 Jeep Cherokee engin turns off
TERRIWILL
Engine Performance problem
2002 Jeep Cherokee 6 cyl All Wheel Drive Automatic
enging turns off while driving and after sitting 5-15 mins it will restart, all the gages are fine and no warning lights come on before this happens, i just replaced the battery and i also notice the recirculation feature is on while the key is in the off position when this happens
Mar 6, 2010 at 5:26 AM
LEGITIMATE007
  • 5,121 POSTS
have your mechanic check the crank position sensor, this fault is very common with these jeeps. also you may want o check the throttlebody and plate, with the idle air control valve,
Mar 6, 2010 at 6:26 AM
