2002 Jeep Cherokee Electric fan
10,300 MILES • 6 CYL • 4WD • AUTOMATIC
KROFIRE
I have a 2002 Jeep Grand Cherokee Laredo. The fan will not go on. He has replaced the relay or some call it a module 3 times and it keeps going bad, it is a NAPA part. His suggestion is to put a mechanical fan on it since it was an option for that model(the water pump is set up for it). He tells me the only con is I might lose some horspower, what do you think.
Jun 24, 2009 at 7:46 AM
  • 110,246 POSTS
If the relay keeps going bad, there is a chance the fan motor is going bad and drawing too much power. As far as the other option, I recommend staying with how it was manufactured.
Jun 24, 2009 at 4:54 PM
