Im hearing a clicking noise when braking. It sounds like its comming from the front. the harder i brake the louder it gets.
May 3, 2009 at 3:13 AM
✓Experienced Mechanic
Do you have any brake pulsation in the pedal when you use the brakes?
May 17, 2009 at 12:49 PM
VICPJ1
MEMBER
There is no brake pulsation in the pedal or the steering wheel....The clicking noise slows down with the vehicle..
May 18, 2009 at 11:01 AM
Check the axle joints and u-joints. Also, see if there is any play in the wheel bearings.
May 18, 2009 at 11:46 AM
