2002 Jeep Cherokee check engine light
82,000 MILES • V8 • 4WD • AUTOMATIC
FLLIMO
My Jeep will not pass inspection. Every thing that is required to pass inpection is fine, but the mechanics computer keeps it from passing, because it says we need a new computer. Our mechanic has put in 3 new computers to no avail, the check engine still come on. Would you have any other suggestions. I am now on a ten day inspection pass.
Oct 16, 2008 at 10:28 PM
KHLOW2008
  • 41,812 POSTS
Hi fllimo,
Thank you for the donation.
Do you mean to say the Check Engine light is always on but no error code is found?
A bad ECM ground would cause the problem if the above is correct.
Oct 17, 2008 at 1:44 AM
JNOVACK
  • 723 POSTS
has this computer been proporly programed with vin # and security codes
Oct 17, 2008 at 6:53 AM
FLLIMO
The mechanic has hooked up his computer and it stated I need a new computer that was the only code, but three computer later it still states I need a new computer. I will be going out of town so I will reply for any other questions when I come back.
Thanks
Oct 17, 2008 at 7:54 AM
JNOVACK
  • 723 POSTS
if computer was not proporly programed it will give that code and make you think the computer is bad also like KHLow2008 posted a bad ground to ecm will also
Oct 17, 2008 at 10:48 AM
