welcome to the forum, check the resistance spec on the ignition coil/s and fuel injectors. An example, the ignition coils, check the primary circuit resistance on all the coils and compare. I look for readings to be close to the same, if one is way out of range compared to the others, I suspect a problem, same thing with the injectors. The test may not be conclusive, but, you have to start somewhere. Also check the 02 heater circuits. Any codes?
Jan 8, 2010 at 8:18 AM
