2002 Jeep Cherokee a/c problem
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
DIK17
I have a 2002 Jeep Grand Cherokee with 95,000 Miles. When I turn on the air conditioning it only comes through the defrost vents, regardless of what the climate control is set on.
Jul 11, 2008 at 1:29 PM
SWILLIAMS
  • 597 POSTS
Sounds like the vacuum control for the vents has a leak. Check the control head in the dash for a leak, if there isn't one there look at the lines under the hood that run from the intake manifold back through the vacuum reservoir and into the interior. A leak in any of them will cause this problem.
Jul 11, 2008 at 5:02 PM
