fuel filter location
LBARC48
Where is the fuel filter and how is it accessed?
Jun 21, 2007 at 1:57 PM
MERLIN2021
  • 17,250 POSTS
Here is the location and instructions on how to change the fuel pump out. This guide will walk you through the steps with diagrams below to show you on your car BELOW.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jun 23, 2007 at 8:41 AM
MOCHADDER
where is my fuel filter located
Jan 18, 2019 at 10:13 AM (Merged)
  • 75,988 POSTS
It is in the fuel tank and is part of the fuel pump assembly, according to the maintenance schedule it does not need to be replaced.
AMYERICKSON
where is the fuel filter located on my 2001 jeep cherokee sport?
Thank you
  • 75,988 POSTS
Its in the fuel tank-no required maintenance-if you wish you can replace it.
Jan 18, 2019 at 10:14 AM (Merged)
NORRISM
How do you replace a fuel filter on a 2001 jeep Grand Cherokee laredo?
MERLIN2021
  • 17,250 POSTS
FUEL FILTER/FUEL PRESSURE REGULATOR Removal (Cherokee & Wrangler) 1. Fuel filter/fuel pressure regulator is mounted in gasket on top of fuel pump module. Fuel pump module is located on top of fuel tank. See Fig. 28 . 2. Manufacturer recommends removing fuel tank for access to fuel filter/fuel pressure regulator. See FUEL TANK . Ensure area around fuel filter/fuel pressure regulator and fuel pump module is clean. 3. Note direction of fuel supply line in relation to fuel tank. Remove fuel supply line from fuel filter/fuel pressure regulator. Remove retainer clamp from top of fuel filter/fuel pressure regulator. See Fig. 29 . Discard retaining clamp. 4. Using 2 screwdrivers, pry fuel filter/fuel pressure regulator from gasket on fuel pump module. Discard gasket. Ensure 2 "O" rings are still on fuel filter/fuel pressure regulator fuel inlet tube. See Fig. 30 . If lower "O" ring is not on fuel filter/fuel pressure regulator fuel inlet tube, remove "O" ring from fuel inlet passage on fuel pump module. Fig. 28: Locating Fuel Pump Module & Components (Cherokee & Wrangler) Courtesy of DAIMLERCHRYSLER CORPORATION Fig. 29: Removing Fuel Pump Retaining Clamp (Cherokee & Wrangler) Courtesy of DAIMLERCHRYSLER CORPORATION Installation 1. Apply a small amount of engine oil onto "O" rings. DO NOT install "O" rings separately into fuel pump module. "O" rings will be damaged when installing assembly. Install NEW gasket on fuel pump module. Install fuel filter/fuel pressure regulator into fuel pump module until it snaps into position. Rotate fuel filter/fuel pressure regulator to install fuel supply line. Install fuel supply line. 2. Install NEW retainer clamp. To install, remaining components, reverse removal procedure. Reinstall fuel tank. See FUEL TANK . Page 1 of 1 3/14/2010 ...
https://images.2carpros.com/forum/automotive_pictures/62217_fuel_filter_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ff_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_ff2_1.jpg
FISHINGMAN1
  • 10 POSTS
stalling out and sometimes eccelerating on its own
engine liter is 4.7
back by the tank but i highly doubt that is the issue. i would check the fuel pressure checked first.
look for vacuum leaks and check the idle control motor for sticking.
BRYANOLSON
where is the fuel filter on a 1997 cheroke
DOCFIXIT
  • 18,828 POSTS
Filter/regulator need to lower fuel tank
DHARRIS2043
Engine Performance problem
2001 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
how do I change the fuel filter
SERVICE WRITER
  • 9,123 POSTS
The jeeps moved them either into the tank or on top of it and have combined them with the fuel pressure regulator.
Post back if you still want to go after it.
DHARRIS2043
I know where the fuel filter is located. it has three ports
two ports has a quick release and the other one I believe is the fuel pressure side. How do i remove this line from the fuel filter
SERVICE WRITER
  • 9,123 POSTS
You may want to post a pic of it. I don't know off hand what style it is exactly. All of them have tabs that have to be released to get them over the llip on the nipple.
https://images.2carpros.com/forum/automotive_pictures/30961_jee_4.jpg
