2001 Jeep Cherokee What can I try next?
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
MUD
I HAVE A 2001 GRAND CHEROKEE. THE PROBLEM I'M HAVING, IS THAT IT DOESN'T SEEM TO WANT TO SHIFT PROPERLY AND IS MAKING A LOUDER THAN NORMAL NOISE WHEN YOU EXCELLERATE. I HAVE CHANGED THE TRANS FLUID AND FILTER AND EVEN CHANGED THE VEHICAL SPEED SENSOR TO TRY TO FIX THE PROBLEM. THIS DID NOT HELP ANY. WHAT CAN I TRY NEXT.
Feb 9, 2009 at 8:56 AM
BMRFIXIT
  • 19,053 POSTS
try and scan for codes
Codes will save you a lot of time trying to guess what next
check and make sure that the engine is running tip top
good luck
Feb 9, 2009 at 8:59 AM
