2001 Jeep Cherokee Water damaged main switch panel for all
2001 JEEP CHEROKEE
153,000 MILES • 6 CYL • AWD • AUTOMATIC
DEEB
  • 7 POSTS
This main switch panel was water damaged resulting in total shutdown. Opened unit and allowed it to dry out-still no response. Removed and checked all fuses under dash and in engine compartment -all OK. Can it
be a relay and if so how to check same.
Nov 26, 2008 at 6:12 PM
BMRFIXIT
  • 19,053 POSTS
Remove driver door module and check for power and ground
TAN ---------------> battery power
black ---------------> ground
no power at the Tan wire check fuse # 26 it is 20A located in the junction block behind right kick panel
if u have power and ground module no good
good luck
Nov 26, 2008 at 11:49 PM
