2001 Jeep Cherokee turn signals
2001 JEEP CHEROKEE
169,000 MILES • 6 CYL • 4WD • AUTOMATIC
DEERSLAYER48
my turn signals or four way flashers stopped working. how do i fix this problem?
Jan 13, 2010 at 4:44 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd check fuse 12--10 amp in the fuse box. Use a testlite on the fuse circuit, the circuit goes hot when you turn on the key. The combination flasher shows to be located close to headlamp switch. After that, I'd have to check feed to and from the multifunction switch.
Jan 13, 2010 at 5:53 AM
