my turn signals or four way flashers stopped working. how do i fix this problem?
Jan 13, 2010 at 4:44 AM
JDL
✓Experienced Mechanic
Welcome to the forum, I'd check fuse 12--10 amp in the fuse box. Use a testlite on the fuse circuit, the circuit goes hot when you turn on the key. The combination flasher shows to be located close to headlamp switch. After that, I'd have to check feed to and from the multifunction switch.
