2001 Jeep Cherokee Temperature Sensor
120,000 MILES • 6 CYL • AWD • AUTOMATIC
BILLYBOY1952
What VOM readings in Ohms do you get when you read across the contacts of teh temperature sensor? The fan motor is OK but the engine will start to overheat when the vehicle is sitting still.
Nov 2, 2009 at 8:54 AM
CHULEGAARD
  • 35 POSTS
usually it's a bad fan relay, where the fan won't kick on when it should. Common problem on these
Dec 9, 2009 at 9:18 AM
